Dear Friends,
Problem:
Both z and x-axis home properly, touching the limit switches and work as per the code, however the y-axis moves in the correct direction for about 3000-5000 steps and then automatically zeros and stops. It doesn't fully home itself.
We are using kmotion KMotion431n.exe (along with latest firmware from it)
Sometimes, we get negative soft limit trigger without the axis actually reaching its soft limit value (happens on y-axis)
Sometimes in the axis window (axis status screen of kmotion), we notice that the values present in the position group are being picked up by the destination group. Is this normal?
We checked for noise but couldnt find any issues with that.
The machine is a home made 3-axis horizontal mill.
Initialization Code:
// Defines axis 0, 1, 2 as simple step dir TTL outputs for KSTEP // enables them // sets them as an xyz coordinate system for GCode
int main() { double T0, LastX=0, LastY=0, LastZ=0, Tau; KStepPresent=TRUE; // enable KSTEP input multiplexing FPGA(KAN_TRIG_REG)=4; // Mux PWM0 to JP7 Pin5 IO 44 for KSTEP
FPGA(STEP_PULSE_LENGTH_ADD) = 63 + 0x80; // set polarity and pulse length to 4us ch0->InputMode=NO_INPUT_MODE; ch0->OutputMode=STEP_DIR_MODE; ch0->Vel=4000; ch0->Accel=400000; ch0->Jerk=4e+006; ch0->P=0; ch0->I=0.01; ch0->D=0; ch0->FFAccel=0; ch0->FFVel=0; ch0->MaxI=200; ch0->MaxErr=1e+006; ch0->MaxOutput=200; ch0->DeadBandGain=1; ch0->DeadBandRange=0; ch0->InputChan0=0; ch0->InputChan1=0; ch0->OutputChan0=8; ch0->OutputChan1=0; ch0->MasterAxis=-1; ch0->LimitSwitchOptions=0x11f; ch0->LimitSwitchNegBit=179; ch0->LimitSwitchPosBit=178; ch0->SoftLimitPos=134178; ch0->SoftLimitNeg=-134178; ch0->InputGain0=-1; ch0->InputGain1=1; ch0->InputOffset0=0; ch0->InputOffset1=0; ch0->OutputGain=-1; ch0->OutputOffset=0; ch0->SlaveGain=1; ch0->BacklashMode=BACKLASH_OFF; ch0->BacklashAmount=0; ch0->BacklashRate=0; ch0->invDistPerCycle=1; ch0->Lead=0; ch0->MaxFollowingError=1000000000; ch0->StepperAmplitude=20;
ch0->iir[0].B0=1; ch0->iir[0].B1=0; ch0->iir[0].B2=0; ch0->iir[0].A1=0; ch0->iir[0].A2=0;
ch0->iir[1].B0=1; ch0->iir[1].B1=0; ch0->iir[1].B2=0; ch0->iir[1].A1=0; ch0->iir[1].A2=0;
ch0->iir[2].B0=0.000769; ch0->iir[2].B1=0.001538; ch0->iir[2].B2=0.000769; ch0->iir[2].A1=1.92076; ch0->iir[2].A2=-0.923833;
EnableAxisDest(0,0);
ch1->InputMode=NO_INPUT_MODE; ch1->OutputMode=STEP_DIR_MODE; ch1->Vel=4000; ch1->Accel=400000; ch1->Jerk=4e+006; ch1->P=0; ch1->I=0.01; ch1->D=0; ch1->FFAccel=0; ch1->FFVel=0; ch1->MaxI=200; ch1->MaxErr=1e+006; ch1->MaxOutput=200; ch1->DeadBandGain=1; ch1->DeadBandRange=0; ch1->InputChan0=0; ch1->InputChan1=0; ch1->OutputChan0=9; ch1->OutputChan1=0; ch1->MasterAxis=-1; ch1->LimitSwitchOptions=0x11f; ch1->LimitSwitchNegBit=181; ch1->LimitSwitchPosBit=180; ch1->SoftLimitPos=95611.2; ch1->SoftLimitNeg=-95611.2; ch1->InputGain0=1; ch1->InputGain1=1; ch1->InputOffset0=0; ch1->InputOffset1=0; ch1->OutputGain=1; ch1->OutputOffset=0; ch1->SlaveGain=1; ch1->BacklashMode=BACKLASH_OFF; ch1->BacklashAmount=0; ch1->BacklashRate=0; ch1->invDistPerCycle=1; ch1->Lead=0; ch1->MaxFollowingError=1000000000; ch1->StepperAmplitude=20; ch1->iir[0].B0=1; ch1->iir[0].B1=0; ch1->iir[0].B2=0; ch1->iir[0].A1=0; ch1->iir[0].A2=0;
ch1->iir[1].B0=1; ch1->iir[1].B1=0; ch1->iir[1].B2=0; ch1->iir[1].A1=0; ch1->iir[1].A2=0;
ch1->iir[2].B0=0.000769; ch1->iir[2].B1=0.001538; ch1->iir[2].B2=0.000769; ch1->iir[2].A1=1.92076; ch1->iir[2].A2=-0.923833;
EnableAxisDest(1,0);
ch2->InputMode=NO_INPUT_MODE; ch2->OutputMode=STEP_DIR_MODE; ch2->Vel=4000; ch2->Accel=400000; ch2->Jerk=4e+006; ch2->P=0; ch2->I=0.01; ch2->D=0; ch2->FFAccel=0; ch2->FFVel=0; ch2->MaxI=200; ch2->MaxErr=1e+006; ch2->MaxOutput=200; ch2->DeadBandGain=1; ch2->DeadBandRange=0; ch2->InputChan0=0; ch2->InputChan1=0; ch2->OutputChan0=10; ch2->OutputChan1=0; ch2->MasterAxis=-1; ch2->LimitSwitchOptions=0x11f; ch2->LimitSwitchNegBit=182; ch2->LimitSwitchPosBit=183; ch2->SoftLimitPos=93321.5; ch2->SoftLimitNeg=-93321.5; ch2->InputGain0=1; ch2->InputGain1=1; ch2->InputOffset0=0; ch2->InputOffset1=0; ch2->OutputGain=1; ch2->OutputOffset=0; ch2->SlaveGain=1; ch2->BacklashMode=BACKLASH_OFF; ch2->BacklashAmount=0; ch2->BacklashRate=0; ch2->invDistPerCycle=1; ch2->Lead=0; ch2->MaxFollowingError=1000000000; ch2->StepperAmplitude=20;
ch2->iir[0].B0=1; ch2->iir[0].B1=0; ch2->iir[0].B2=0; ch2->iir[0].A1=0; ch2->iir[0].A2=0;
ch2->iir[1].B0=1; ch2->iir[1].B1=0; ch2->iir[1].B2=0; ch2->iir[1].A1=0; ch2->iir[1].A2=0;
ch2->iir[2].B0=0.000769; ch2->iir[2].B1=0.001538; ch2->iir[2].B2=0.000769; ch2->iir[2].A1=1.92076; ch2->iir[2].A2=-0.923833;
EnableAxisDest(2,0);
DefineCoordSystem(0,1,2,-1); SetBitDirection(45,1); // set Enable Signal as Output SetBit(45); // Enable the amplifiers // Add a small amount of Coordinated Motion Path smoothing if desired // Tau = 0.001; // seconds for Low Pass Filter Time Constant // KLP = exp(-TIMEBASE/Tau); KLP=0; // force to 0 to disable // printf("Tau=%f KLP=%f\n",Tau,KLP); /* for (;;) // loop forever { WaitNextTimeSlice(); // Service Amplifier disable after no activity for a while if (ch0->Dest != LastX || ch1->Dest != LastY || ch2->Dest != LastZ) { // we moved - enable KStep Amplifers SetBit(45); T0 = Time_sec(); // record the time and position of last motion LastX=ch0->Dest; LastY=ch1->Dest; LastZ=ch2->Dest; } else { if (Time_sec() > T0 + 10.0) ClearBit(45); } if (ReadBit(180) == 0) { printf("Bit State Pressed"); } } */
return 0; }
Homing Code:
// Configuration and Homing program for a 3 axis System // Limit switches are disabled and used as a home switch // then they are re-enabled
main() { int SaveXLimits,SaveYLimits,SaveZLimits; //place to save limit switch settings DisableAxis(0); // Disable all axes DisableAxis(1); DisableAxis(2);
// Set the axis parameters here // after everything is configured in the KMotion Screens // use copy C Code to clipboard on the configuration screen // then paste here. Repeat for each axis // disable the limits (first save how they were set) SaveXLimits = ch0->LimitSwitchOptions; SaveYLimits = ch1->LimitSwitchOptions; SaveZLimits = ch2->LimitSwitchOptions; ch0->LimitSwitchOptions = 0; ch1->LimitSwitchOptions = 0; ch2->LimitSwitchOptions = 0; // enable all 3 axes and begin servoing where we are EnableAxis(0); EnableAxis(1); EnableAxis(2);
// Home Z up first - jog until it sees the limit
Jog(2,600); // jog slowly positive while (ReadBit(183)) ; // loop until IO bit goes high Jog(2,0); // stop while (!CheckDone(2)) ; // loop until motion completes DisableAxis(2); // disable the axis Zero(2); // Zero the position EnableAxis(2); // re-enable the ServoTick Move(2,-1000.0); // move some amount inside the limits while (!CheckDone(2)) ; // loop until motion completes ch2->LimitSwitchOptions = SaveZLimits; // restore limit settings
// Home X next - jog until it sees the limit
Jog(0,-600); // jog slowly negative while (ReadBit(179)) ; // loop until IO bit goes high Jog(0,0); // stop while (!CheckDone(0)) ; // loop until motion completes DisableAxis(0); // disable the axis Zero(0); // Zero the position EnableAxis(0); // re-enable the ServoTick Move(0,1000.0); // move some amount inside the limits while (!CheckDone(0)) ; // loop until motion completes ch0->LimitSwitchOptions = SaveXLimits; // restore limit settings
// Home Y next - jog until it sees the limit
Jog(1,-600); // jog slowly negative while (ReadBit(181)) ; // loop until IO bit goes high Jog(1,0); // stop while (!CheckDone(1)) ; // loop until motion completes DisableAxis(1); // disable the axis Zero(1); // Zero the position EnableAxisDest(1,-95611.2); //EnableAxis(1); // re-enable the ServoTick Move(1,-94611.2); //Move(1,1000.0); // move some amount inside the limits while (!CheckDone(1)) ; // loop until motion completes ch1->LimitSwitchOptions = SaveYLimits; // restore limit settings
DefineCoordSystem(0,1,2,-1); //Define XYZ coordinated motion axes }
Do help us Thanking you
